[SOLD] Magnum roller camshaft new in box
modart440
Rating - 80%
4   1   0
MAGNUM ROLLER CAMSHAFT NEW IN BOX Custom Crane grind.Grind number
HR-214/ 325-2S-12 214 degrees intake 220 degrees exhaust @ 0.050duration. 276 degrees intake/ 282 degrees exhaust advertised duration.0.520 lift intake/ 0.531 lift exhaust using 1.6 rockers. (have rockers for sale in another ad new crane 1.6 with new shafts)Cam is 112 LSA.
Have a set of used magnum roller rockers with guide plates and spyder hold down,also have a set of oil through pushrods that go with it.175.00 obo located near Toronto ,Ontario
How does this compare to a stock 2000 5.9 cam?
I'm not really ready, but I have one with a spun bearing on my list of back burner projects.
if your referring to specs the only comparison numbers I have is for a 2001 R/T 249int duration 269 exhaust duration 458 intake lift and 467 exhaust lift I don't have any at 0.050 numbers. Maybe somebody with stock magnum cam specs could chime in.
thanks
Stock 5.9 cam is .417/.417 lift,190/205 at. 050.Retainer hits valve guide about .510 lift.Buy the Hughes spring/retainer bumps the range to .540,.550 lift.The stock cam peaks 4600,4800.The Crane should be good to 5400,5600 for peak power.That is a good price,GLWS.
Hmm, is the stock spec 417/417 lift or 458/467?
...wait is that 417 lift number at .050 as well?
Good info.
.417 total lift,not @.050. That .458/.467 cam.is part of a smog legal package for early to late nineties 5.9 Magnum trucks.It has a cam,reprogrammed ecu,and exhaust for a 30 to 50 h.p. smog legal gain.
Dang!
Great info, though.
Nice to learn something.
