[WANTED] Magnum Throttle return spring bracket
Jeg's appears to have them in stock.
https://www.jegs.com/i/Mopar-Perfor...m_term=4581596255650123&utm_content=Evergreen
In lieu of that, just use an LA bracket from your parts box, or new:
NEW Mopar 1974-up 318/360 Throttle Return Spring Bracket 2BBL | eBay
Since the LA manifold bolts are at an angle and the Magnum bolts are vertical, you only need to bend the bolt tabs a bit to bring everything into line. The bolt spacing is identical.
I did not know that about the bolt spacing, i dont have an LA one laying around either but its good to onow for future refference
