Main and Rod Bearings
  • Thread starter Thread starter wedgehead1
  • Start date Start date
W
wedgehead1
Guest
Need help trying to locate 20/20 main and rod bearings for a MP 3.79 steelbolt crank. They need to be chamfered for this crank. No one sells more tha .010 in the H bearing series. Help!!!! Wedgehead1
Have you checked Summit's web site? They have a ton of small block mopar bearings listed on there.
Clevite "77" MS1266P20 Main Bearing Set
Main Bearings, P Series, Full Groove, .020 in. Under Size, Tri Metal, Mopar, Small Block LA/Magnum, Set of 5 --- ** Bearing Usage: Direct replacing ** Grooved Bearing: Yes ** Groove Location: Upper and bring down ** Groove Style: Full ** Bearing Material: Tri metal, TM-77 ** Quantity: Sold as a set of 5.
and either yourself, or a machine shop can chamfer the edges. seems your options a limited. im too lazy to look for the rods..lol
cheers.
