inkjunkie
Once again I have proven to myself how important it is......and that blowing it off is asking for trouble. Our 99 Explorer starting acting up. While making tight turns it was acting like it was inn 4 wheel drive. It has the Control Trac t-case in it, so it was. Joined an Explorer forum to ask a few questions. Ends up that the clutch in the t-case was seized. Before I pull the old one out I decided to change the fluid, which I have never done in the 100k that we have put on it. I pulled the plugs on the case and was greeted by black as coal atf that had the aroma of old gear oil. And was not the least bit slickery at all. Going ot put the front drive shaft back in and see what happens before pulling the old t-case out. So I have learned my lesson, again, about changing fluids. I know there are some folks that say short duration fluid changes are a waste of $$ but I will be putting everything back on a yearly/biyearly change for transmission, t-case and gear oils. Just not worth pushing your luck to save a few $$'s.....
