Making doors so they are removable?
MPerry
Member
Massachusetts
Does anyone have pictures and info on how to do this?
There used to be pictures and info on converting stock door/hinges to make removable doors on moparts when carl was a moderator.
Unfortunately all his information disappeared long ago!
Its called a quick release pin used in air craft and racing.Install new bushing and get a 5/16 or 3/8 QR pin and bore the bushing to fit.Pins are then installed from the middle of the door up and the other from the middle down.This can also be done with large nail that has been drilled with a hole for a safety pin,and a flat washer to the top to aid in removal,mrmopartech
I kind of figured a quick pin would be used. I need to see how the hinges are modified so one person can install the door. ;) ~Mike~
