[FOR SALE] Mancini Throttle Bracket, Small Block with W2 Heads
dart540
south western PA.
Rating - 70%
7   3   0
Mancini Throttle Bracket, Small Block with W2 Heads #MRE AR1062
These throttle bracket kits solve the problem of hooking up your throttle linkage when using a taller than stock intake mainfold. These well engineered kits are adjustable in order to accommodate different carburetor spacer heights, and they are flexible enough to work with either Holley, Demon, or Edelbrock carburetors. An additional feature of these kits is the fact that they will allow use of the Lokar cable kickdown system for control of your automatic transmission. There is no provision on these kits for the factory style kickdown linkage.Brand New Never Used.
$50 + shipping.
Thanks Stan.
attachment.php
