Manual Box with Large Sector Shaft
Nelson7604
Active Member
Beaumont, CA
I found a manual steering box, but I don't know what car it is out of or what year it is. It has the large sector shaft. Which manual steering boxes had the larger sector shaft? Thanks
Check it out, there is good info and pictures here;
http://www.bigblockdart.com/techpages/steeringbox.shtml
And if anyone is interested, I have personally used a van box (large sector with the different sector cover) in an A body with 73 and up steering linkage. It bolted up fine and only needed a little clearancing to clear the schumacher /6 to bigblock spool conversion mounts.
Thanks for the information. With this in mind, would it be possible to use this box in my '72 Dart with a 318 (given the correct pitman arm with the bolt to the center link pointing up)? Would there be clearance issues? Clocking issues?
