[Found!] Manual Steering Box Mounting Bolts 71 Duster
blown340
Chico, Ca
Hi, Looking for the 3 mounting bolts for a manual steering box to k-frame 71 Duster V-8 Please let me know a total cost including shipping to 95928 Chico, Ca
Thanks in advance, john
I have these two sets. The 12-point bolts are from a 69 Dart GTS with manual steering. The other set is from a 74 Duster with power steering. Both bolts are identical except the heads. Both are the same length & diameter. If you know which ones are correct, I'll sell a set for $47 shipped to you.
There are some headers that will not fit with the 3/4 6 point heads on the box. They hit a tube. The 1/2 12 point heads are the correct bolts. for your car.
I just experienced that myself, you can't get a wrench in there "edgewise"
Thanks for the heads up, I have 12 points coming, Thanks to all that replied
