71Scamper
Mopar runs thru my veins!
Aluminum crank and waterpump double row pulleys. Also, a chrome double row alternator pulley with nut to compete the setup. This setup is for a small block with a long nose water pump and will not work with power steering. The alternator pulley will work with GM CS style alternators. Can be used with chrysler alternators if you use a .250 spacer. I don't have the spacer. I'll take $150 plus shipping
