master cylinder conversion question, 65 barracuda
1965cudav8
Portland, Maine
As of now, my car still has stock 9" drums, manual. I pulled the master cylinder today since it was 100% shot. Can i order a dual bowl master as a replacement and just hook up the brake lines that way? Im fairly nervous about running this single bowl drum system with 9 inchers...It definitely does not seem safe. I aim to do a disk brake conversion in the future but dont currently have the money. Any help would be much appreciated
D
yes you could use a dual resevoir master cylinder. yu just need to aquire a prop valve fron a early 70's a body-drum equipped car. use the master from the same application.
eg; 1971 dart with 9" drums. you may have to fab an extra line or two but.......
