Master Cylinder Recommendation
billkrz
Hello. This is a continuation of my thread "Need Help Identifying Brakes Please". Now that you all have helped me identify what I have: 70-72 B/E body front discs and 11x2 1/2 inch rear drums (probably H-D B Body from same era), my next question is what Master Cylinder do you recommend?
Currently, the car has the original 1968 Dart Drum brake master and power booster. From what I've read, this is dangerous because of the brake swap.
Is there something that would easily bolt up to my power brake booster? Do I also need to add a proportioning valve or is this built in to the master?
Thanks again for all assistance.
Bill
Thanks. Regarding the 73-78 B body Master cylinder recommendation, will this bolt up to my '68 power booster? Also, do I still need an inline proportioning/balance valve or is this built in?
Bill
