coolbreeze
LoweLife
What year master cylinder should I use on my 64' Dodge Dart wagon? I am using the stock 9" drums on the front, 10" drums in the rear. Also, what should I use for a "balance" valve? When I go to buy my master cyclinder the brake sizes come into play and I have both!!!! Will the stock block work by just blocking the port to the rear and running the rear line to straight to the back?
