Bought an aftermarket mechanical temp gauge to replace OE gauge the does not work. I have a 318 out of a 1982 Plymouth Diplomat in a 1969 Dart GT convertible.
On the intake manifold there are two extra plugs by the thermostat housing. I hope to use one for the new gauge.
My problem is I can not get the old plug out. Factory sending unit hole is too small to use.
Is it too close to the carb or other internal parts to use a torch or is there another trick to loosen it? Thank you in advance.
