Caliscamp72
Mostly sane GM Destroyer
If any one is interested I have a MR Small tandem diaphragm brake booster with cantilever arm and bracket , master cylinder pushrod, and lower braces . They were removed from my scamp last year and have had them sealed and stored away , the booster worked fine when removed ,no fluid entry or damage to diaphragm , lever assembly has been taken apart cleaned up inspected and greased then reassembled , braces are epoxy painted black , I also have the master cylinder which worked with no leaks . I'm in San Diego north county area and I would take 75 bucks for the lot , plus the ride . I changed over to the manual offered by Cass at DR DIFF, so I don't need them . Have a great weekend . Boot is not in the greatest shape and clamp bolt has a bend otherwise good.
