mad accountant
Picked up at an estate sale. $150 for all. Local pick up only unless you want to arrange shipping. These things are heavy! Pics available upon request. All are used but in good shape.
#6227-1 and 6227-2 Spring Compressor and Alignment Shaft
#C-3863 Front Clutch Assembly Remover and Installer
#6497 Transfer Shaft Retaining Nut Wrench
#L4435 Bearing Retainer Wrench for Chrysler and Jeep Differentials
#L4440 Overrunning Clutch Assembly Installer
#6312 Cylindrical Gauge Bar
#6311 Flat Gauge Bar
2 of #5059A Spring Compressor
#5067 Seal Installer
#6599-1 and 6599-2 Automatic Transaxle Valve Pressure Test Plate Set
#6056 Air Pressure Checking Plate
#C3575A with SP 2784 and SP 2878 Front Clutch Piston Spring Compressor
#6550-3 Transmission Sprocket Remover and Installer
#5058 2-4 Return Spring Compressor
#6057 Disc Used With 5059A Spring Compressor
