I putting a 408 stroker in my 73 dart swinger ,I thinking about using a milodon 30940 8 qt oil pan with hooker super comp headers. will it fit and what do I have to do to make it work ? has anyone used hughes camshaft her3624aln-10 ?
THE avatar is the hurst hairy olds. the pan clears the headers ,now lets see if it clears k member. you have to drill a hole in the baffle for the dipstick.
I have a 1973 dart swinger 408 stroker 500hp ,904,3500 stall ,3.50 gear
1970 442 conv 455 400 hp stick 3.42 gear
You will likely need to cut a little triangle out of the K-frame lip on the passenger side to clear the right front corner of the sump during installation with that Milodon 8qt pan. But it's worth it and is a little shallower than a Moroso.
I also know several headers do not fit because of the flared sump. I use TTI on my race car and they fit very well with no clearance issues, including the ground.
