Have installed Milodon #30750 4 quart oil pan on 340 small block yet takes 6 quarts of oil to register full. That's 5 quarts in the pan and 1 in the filter. Contacted Milodon tech support. Reason for discrepancy, per Milodon, was the use of baffle in pan. I take it as oil collects unevenly on either side of baffle and cannot equalize for lack of hole between the two sides. Dip stick is measuring the lower of the two levels. It takes the 6 quarts to fill the baffle side with the lesser level of oil. Has anyone else had similar issue with this oil pan? If this is true I can't believe my dip stick. Any comments? Have verified my dip stick and tube length.
