[SOLD] MINT lower control arms with poly bushings
metallidart
member me?
Legendary Member
East Palestine, Ohio
I was going to use these on my Dart Sport, weld in the reinforcements and also weld on the aftermarket sway bar tabs (whenever I actually decided to purchase the sway bar.). I pressed the pivots out, the sleeves are still in the arm, and on the pivot. Included are brand-new poly bushings. Or, remove the sleeves and install oem-style rubber ones. I glass bead blasted these and they look perfect. Believe it or not, those are bare metal with a rust preventative (crc) sprayed on them. No paint. I took these off of a 72' Demon about 10 years ago, and I kept them because they were so clean. I am going a different route on the Sport, so I'm getting rid of everything. I'm asking $75 plus shipping. They are located in eastern Ohio, 44413. Send me a PM!
