dart540
MP #P4529838 SMALL BLK CAM BOLT NEW $10
MRE#6030269 B/RB CAM BOLT AND WASHER PKG NEW $5
CRANE CAMS # 991636-1 CAM BUTTON SPACER V-8 W/3-BOLT GEAR NEW $10
MRE-7704-1 7.800-8.800 CHECKING PUSHROD $10 USED
JEGS #80682 8IN.-9.170 CHECKING PUSHROD $10 USED
COMP CAMS # 7711-1 7.800-8.800 CHECKING PUSHROD $25 USED
HUG # 6960 DIPSTICK FITTING QUICK DISCONNECT SM/BB NEW $5
BIG BLOCK 8-BOLT FLEX PLATE USED OUT DATED $35
MRE 317 2EA BRAKE ROD RETAINING BUSHING NEW $3
MRE AX42 THROTTLE BRACKET 68-70 340 4-BBL ENG NEW $10
MRE #1060 TALL SINGLE PLANE RETURN SPRING BRACKET BIG BLOCK NEW/ OPENED $20
MRE #AR-1330 CRANKSHAFT PULLEY SPACER 0.125 THICK NEW $10
MOROSO #46190 WHEEL STUDS NEW OPENED 9 ONLY $10
PM ME FOR PICS AND NUMBER
THANKS STAN.
THANKS STAN.
