Yote
Getting to old to hang on to this stuff. Most was off of, or for my ‘72 Demon, but not all.
Speedo gear —- $20. - 37 tooth - used but looks good.
Speedo housing- $20.- used, some deterioration on threads, but still usable.
Wiper arms—— used,- $10. for all - 3-14” — 1- 17”
Window handle- used,- $3.
Hub covers——- $15.- Chrome,New in box. For wheel center opening of 2.95 “
Washer resivoir cap — used, - $.50
Steering column spacer- used -$1.50
Wiring harness - $10.- horn,headlights,front side marker. One tab broken on bulkhead connection.
Z Bar ball mount- $5. With spring clip.
Fuel sender lock rings- $1.00 ea,- 2- new— 1 original
Fuel sender- $7.50 -new, will probably need meter match for correct operation.
Spark plug wire clips- $2.50 for 2.
Radio speaker - $35.- new , 4x10” , 4 ohm. Bought set of two only needed one.
Dash bulb sockets- $5. - 4, with bulbs
Throttle pedal- $25. - cleaned/painted with 24” cable.
Rear shackles- $10.- sand blasted/ primed. For a pair.
Battery tray- $7.50 -cleaned, repaired hole, painted with support brace.
Glove box support cable.- $1.50
Kick panel- $7.50- black, passenger side.
Headlight retainer rings. $5.00 pair - chrome ,like new.
Tie rods - $15. pair- still tight but need new rubber boots.
Exhaust manifold- $75. - casting number 2951916 with heat stove. Not sure what it fits, that is up to you.
Tail light - $150. - for Demon, passenger side, chips repaired, lens polished. With housing, cleaned /painted.
With used gaskets still serviceable.
USPS Money order, I don’t do PayPal.
Dang it, Can’t seem to upload photos. PM me and I can send photos via text, of anything you are interested in.
Yote
Yote
