[SOLD] Misc. OEM & aftermarket parts
Locomotion
Florida
Miscellaneous parts for sale. Group photos at bottom. Can provide more info & photos.
All prices + shipping from Florida 32117.
1 - Milodon 45225-8 1.60” MegaFlow exhaust valves
, 21-4N stainless steel, 3/8” stem, 5.000” O.A. length, NEW - $125.00
2 - Milodon 45640-8 2.02” Street intake valves, 21-4N stainless steel, 3/8” stem, 4.930 O.A. length, NEW - $100.00
3 - Moroso 64700 5” Mopar aluminum pulley, has 1 offset bolt hole for pre-'72 balancers but can be used on newer ones by using 3 bolts. NEW - $60.00
4 - Russell 4022 6AN fuel inlet fittings for Holley dual feed carbs. NEW - $8.00
5 - Mopar 8 3/4” adj. Pinion Snubber w/grade 8 bolts. VG condition - $45.00
6 – Moroso 46200 1/2”x20 screw in axle studs, set of 5, NEW - $20.00
7 - Mr. Gasket 9126G Aluminum fuel pump block off plate, NEW - $8.00
8 - Taylor Cable 842060 plug wire seperators NEW (One 2 wire separator missing.) Both packs - $8.00
9 - KB 0990x300K wrist pins NEW - $30.00
10 - 727/904 5.0 kickdown band lever. Used - $25.00 (SOLD)
11 - 727/904 3.8 kickdown band lever (2 available), Used - $25.00
12 – 904/7290 trans yoke for 7260 u-joint, used - $25.00
13 – OEM Mopar small block rocker shaft bolts & retainers, used - $15.00
14 – Mr. Gasket/Moroso style water pump motor pulley, used - $7.00
15 – Moog K7049 Idler arm bushing kit, '71-'72 A-body, NEW - $20.00
16 – OEM 360 connecting rod cores 3818645, used - $20.00
17 – Moroso 25150 (?) small block lifter valley baffle, used - $20.00
