[SOLD] Modified 273 ROCKER ARM ASSEMBLIES
Locomotion
Florida
* 273 rocker assemblies - Rocker arms are machined for lock-nuts and have the original Crane-style slotted adjusters. They've been cut for spring/retainer clearance and have OEM grade 5 bolts.
$150.00 + shipping from 32117 (photos 1 - 4)
_________________________________________________________________
Rocker arms are bushed down to smaller diameter, but thicker wall shafts are used. Very light clearancing for springs/retainers and have the "good" allen head/12 point adjusters & lock-nuts. Heavy duty hold-downs & grade 8 bolts. Grade 8 washers added to compensate for longer than OEM bolts.
$300.00 + shipping from 32117. (photos 5 - 9)
Sorry, no PayPal. Money order will work.
1-
2-
3-
4-
5-
6-
7-
8-
9-
When you bushed them to you have ratio blueprinted/corrected like we used to do
on our stockers in the old day before roller rockers?
I believe I had Rocker Arm Specialists do the bushed rocker arms, maybe about 15 years ago. I never rechecked the actual ratio but passed when checked in tech. I was short & still losing a bit through geometry. I also figured out I could run beehives without clearancing and went to Harland Sharps shortly afterwards.
