[SOLD] Mopar 3512100 1971 340 V8 intake manifold $150
LS&S
Aylett, VA
Rating - 0%
0   0   0
For sale: Chrysler 3512100 1971 340 V8 intake manifold. This is the factory high rise cast iron intake manifold that came on all 1971 340 engines equipped with Thermoquad 4 barrel. If you have a 1971 A-body or E-body with 340 V-8 4-barrel engine, this is the manifold you need if you are going to restore it to original. The story is this: I was going to put this manifold on a 1973 360 Dodge. I drove from Virginia to North Carolina to pick up the manifold and pay for it. I then paid NAPA auto parts machine shop to tank and clean the manifold. They coated it with the light oil as a rust preventative. I later decided against using the manifold and purchased an aftermarket manifold. It is in excellent condition. It only needs a spray with CRC brake fluid cleaner and wipe down with rags. Then it can be painted whatever engine color matches your 1971 engine. This manifold is Numbers matching for all 1971 340 V8 Chrysler 4 barrel engines. It is date matching for all 1971 Chrysler 340 4 barrel engines made after October 12, 1970. Of course, it fits all LA engines. My price is $150 plus shipping. I would probably use Fedex ground, but am open to using any shipper in my area. Richmond, VA. PM me if interested. Thanks, Ben
Why in the first picture does the choke well open up into the exhaust cross over? My 72 340 factory high TQ manifold the choke well is closed.
The 72 manifold uses the same choke as the 71. They went with the electric assist in 73.
Good to know! Manifold is still available.
Ship from 23116. Fedex is usually cheapest because ship from local distribution center.
Box Shipping estimates.
48lbs
22.5"L
14.25"W
7.25"H
What is the date on your 72 manifold? It may be for a 73 car. Can u post a pic of the number and date. Thanks. Kim
Yes- I see. It is probably the same - now that I look at the photos. Mine has the well covered. I bet if removed it is also open. My mistake.
