[SOLD] Mopar 360 Magnum, 4spd, A body complete swap
813Demon340
Northern Nevada
I have a complete 360 Magnum 4 speed A body swap for sale. From carb to pan, radiator to 8 3/4 rear end, plus extras! Whats included:
-2002 360 Magnum (60K on motor) with Edelbrock RPM air gap(new), 680 Quicktime carb (new), Mopar Elec ignition, new water pump, plugs, cap, rotor, Schumacher motor mounts(new) (A body 72 or below), Kevco oil pan (new). Stock serpentine set up, A/C delete (but I do have the A/C compressor), P/S pump, etc. Mini starter, etc. Runs good.
-Aluminum radiator and hoses (new)
-A body A833 4 speed (used), with factory A body shifter, Z bar, factory bell housing & dust cover. New Mcleod diaphragm clutch, throw out bearing. Powdercoated rear crossmember
- New driveshaft (72 Demon length) and U joints
-Factory 4 speed pedal set up with rod & spring.
- A body 8 3/4, stock A body width (came out of a 71 Duster) with 4" bolt circle axels, complete with 2:76 open diff, e brake cable, missing drum hats. Comes with big bolt pattern 11" rear drum assemblies.
-8 3/4 third member 3:91 sure grip, 741 case, should be gone through.
-New 360 magnum crank pulley for use with V belt style pulleys and old style timing cover.
-1968 Cast Iron A body 340 4 speed bell housing.
-3 speed driveshaft for parts
This basically an entire drive train for a Mopar A body. Find a clean demon duster dart scamp valiant dart sport barracuda gts formula s body then drop this in with some headers and you're done! Dodge Plymouth Chrysler
I WILL NOT SELL PARTS SEPARATELY at this time, All or nothing. If you are interested in something individually let know andI will contact you if I break it all up.
PM or get my email from my profile, Located in Reno NV 89511 and prefer pick up
$4000
