[SOLD] MOPAR 4 SPEED TRANS. BOLTS
jsjs1212
1969 DART SPECIALIST
Decatur IN
Rating - 98.2%
55   1   0
Hi, 1set of original Chrysler manual transmission bolts to bellhousing. Also included are 2 original Chrysler transmission mount bolts. They have been cleaned and black oxide coated. $9.99 + actual postage. I ship fast! Thank you.
So what kind off bolts would you use with an aluminum bellhousing?
Longer ones, I did a swap and used the same bolts and they physically pulled out of the aluminum bell housing while I was driving. I replaced them with grade 8 longer bolts and everything is fine now. I may be wrong about these, but the aluminum bells are threaded all the way through, so too long is not a problem, but too short is not good.
