challengersteve
You are buying a Mopar Big Block 383 400 440 Oil Pan.
This is the one with 699 stamped into the bottom and originally was from a early 70's C Body.
This is the one used for the Big Block A Body conversion as it has notch in the side for the idler arm clearance.
This is in Very Nice Condition and has been cleaned, blasted and primed in a self etching epoxy primer.
The pan gasket flange is perfect and the oil drain plug threads are excellent as well.
This is 100.00 INCLUDING SHIPPING in the CONT USA. Canada and other International shipping would be more.
I accept Paypal and credit cards over the phone.
Thank you very much, Steve Schweitzer
