[FOR SALE] Mopar Nat's 5.7 hemi and 408 stroker for sale
krw340
I'm in row I- 17 with a 2014 5.7 hemi, from a ram 4x4, with only 75 miles. Truck was stolen, wrecked, and recovered. $3500
408 stroker, scat crank, KB 356-030 pistons, Howard's 710581 flat tappet cam, ported J-heads, new 2.02 stainless valves, Summit balancer, 670 Holley. $4000 OBO
I still have both motors.
The 408 motor was run in a 1977 Power Wagon one ton, long enough to break the camshaft in and was driven about 20 miles. I used Brad Penn 20W50 along with zinc additive during break-in, and used 92 octane pump gas. Intentions were to build the motor for low end torque to use it for pulling a car hauler and plowing snow. I purchased another truck, so now the motor and Power Wagon are up for sale. After pulling the motor I took it apart and installed new rod and main bearings that were measured for clearance, installed a new set of Cometic head gaskets, cleaned all parts, and assembled motor.
1978 360 block bored .030", cylinders notched for rod clearance, and block was squared and decked. I also installed the oil crossover tube modification.
The heads have been ported nicely, which look to be done professionally to a stage 2 or 3 level. They have new stainless valves, bronze guides, and heavy duty springs to match the Howard's camshaft. .030" Cometic sheet metal re-usable head gaskets were installed. The roller rocker arms I'm not sure what brand they are but might be Pro-forms. I up-graded the adjuster screws to Crane Cams brand and cut the ball and cup push rods to length.
I port matched the intake manifold to the head intake ports and the exhaust side to a set of Flowtec headers.
The crankshaft (rotating assembly) was balanced and was told by the Machine shop owner it looked like a Scat (chamfered) cast crank. Crank was turned .010" on the rods and .020" on main bearings. The piston domes were trimmed on the edge on the valve side to clear hitting the head.
The quench was measured to .036". Rod and main bearing clearance was measured at .002-.003". Valve lash was set at ¾ turn. Camshaft was installed straight up with a 3 way timing gear adjustment. The motor was primed and has 75 lbs. oil pressure with Valvoline ZR-1 10W30
Compression Calculator
Cylinder Head Volume (cc) 62 Cylinder Head Vol (cubic in.) 3.782
Piston Head Volume (cc) 25 Piston Head Vol (cubic in.) 1.525
Gasket Thickness (in.) .030 Swept Volume (cubic in.) 50.769
Gasket Bore (in.) 4.2 T.D.C. Volume (cubic in.) 5.509
Cylinder Bore Diameter (in.) 4.02 Gasket Volume (cubic in.) 0.443
Deck Clearance (in.) -.019 Deck volume(cubic in.) -.0241
Note: Neg. number above
deck, Pos. number below deck
Stroke (in.) 4
STATIC COMPRESSION RATIO 10.216
Rod Length (in.) 6.123 Adjusted Stroke (in.) 3.393
Intake Closing Point
(degrees) ABDC @ 0.050 lift
plus 15 degrees
DYNAMIC EFFECTIVE
COMPRESSION RATIO 8.817
1978 360/408" Block
Bored .030" /Squared
Notched for rod clearance
Oil Crossover Tube Modification
New Freeze plug set
Rotating Assembly
Chamfered Crank Shaft
Rod rotating-513
Rod rotating-513
Rod bearing 46.5
Rod bearing-46.5
Oil allowance-6
Piston & Pin-591.5
Locks (1 set) X
Rings (1 set) 56.5
Rod reciprocating- 208
Bobweight total- 1981
Note: 50% Reciprocating 100% Rotating
Keith Black Pistons- KB356-030
Stock rods
ARP- main bolts
ARP- rod nuts and studs
Clevite rod bearings
King- main bearings
Reproduction truck oil pan
Modified Dipstick Tube
Melling- HV Oil Pump
Wix- Oil Filter
Summit- SFI harmonic balancer #A640195
587- Iron Heads Nicely Ported
Stainless Steel Valves
2.02 intake/1.66 exhaust
Bronze valve guides
Adjustable roller rocker arms (unknown brand)
Crane Cams- rocker arm adjuster screws #crn-99802-16
Custom Made Ball & Cup Pushrods
Cometic- Head gaskets #245-C5633-030
Howard's- Cam & lifters #CL710581-10
Hydraulic flat tappet 230/236, 277/283, .531"/.537", 110+4 L/C
Double roller timing chain & gear set
Mopar-Timing chain tensioner DCC-5007709
Stock Mopar Distributor
Standard Dist. Cap & Rotor Plug wires
Champion spark plugs RN12YC
Hardened Dist. Gear Drive DCC-3690715
Hardened fuel pump eccentric
Carter Fuel Pump #M6866
Mickey Thompson- Valve covers
Edelbrock Performer 318/360 Intake Manifold
Hollley- 670 Street Avenger Carb
Howard's computer dyno on this build with a 750 carb is 400 hp. @5000 rpm's & 475 @ torque 4000 rpm's.
Located in Michigan 48661
Prefer to be picked up
You will have to pay shipping cost and make shipping arrangements.
Located in Mid Michigan
48661
