[WANTED] Mopar offset hangers
Cudaboy17
Active Member
Winnipeg
Looking for a set of new mopar offset leaf spring hanger brackets. Mopar part number should be P4120077. Also looking for the offset shackles which are part number P4120075. Thanks for looking.
Instead of using offset brackets, you can just redrill the mounting holes and relocate the brackets you already have.
Thanks for the suggestion but this is temporary before I restore the car so I want to stay as much bolt on as possible.
