Mopar parts for sale in Atlanta, GA.
a34
The Etowah Flash
Etowah, Tn.
Rating - 0%
0   0   0
Small block B and C body, 727 318/360 with torque converter - $150
Small block 727 inspection shield - $20
4-spd trans with cast iron bellhousing, clutch cover, trans mount & inland shifter with handle from ‘67 273 Barracuda - $450
4-spd trans with aluminum bellhousing, shifter rods, clutch fork with boot, trans mount & Hurst shifter with handle from ‘69 Barracuda. Numbers on tranny - c99129, tail c99126, stamped pad PP8332819 with 152 beside it and vin of 9B360756.- $450.
4-spd trans with aluminum bellhousing, clutch fork with boot, trans mount & Hurst shifter with handle. Also has underdash reverse lamp light and wire. Numbers on tranny - c99129, tail c99126, stamped pad PP8332817 with 0333 beside it - $470.
Aluminum bellhousing with clutchfork – 3515734, 10.5”, ‘72-3 A, B, E 340 engine. $150
2 small block forged steel cranks - $50 each
exhaust manifolds 67-69 a-body 273/318 - $100/pr
manual steering gearbox - $100
power steering gear box - $40
distributor, electronic small block, 3755201 - $20
distributor, single point 440, 2642252, 1966 c-body, all trans - $20
distributor, single point 361-383, 2444676, 1965 B & C-body, all trans - $20
small block stock valve covers - $40/pr
70 383 stock valve covers – $100/pr
67 273 finned small block valve covers - $120/pr
m/t cast aluminum small block valve covers $50/pr
fm radio converter - $40 each
small block balancers - $5 each
70-74 Challenger full wheelcover small ding - $10
right angle oil filter adapter - $50
small block flywheels - $40 each
new black jack aluminized headers small block a-body - $75
seven blade fans - $50
power steering pumps with bracket and pulley, Federal and Saginaw - $50
3 each 1967-68 14”X5.5” magnum 500 wheels. Nice chrome, one has a small bend in lip. Easy fix. $275/set
Set of 4, 1967-68 14”X5.5” magnum 500 wheels. Nice chrome with center caps, not lugs. $500
Set of 4, 14"x5.5" big bolt pattern Rallye wheels, wheels only. $200
All kinds of Dodge and Plymouth full wheelcovers – send pic of what you need and I’ll match it up.
3 each original Dart, Duster exhaust tips, 2 are in nice shape, but need rechroming for show quality. $100 each.
The big stuff must be picked up in Atlanta, Georgia. The small stuff I can ship. Pm me here for pics or any questions or email me at r_gann@bellsouth.net
Sold one of the trannys, but have aluminum bellhousing - 3515734. 10.5" fits all small block a, b, c or e-body. $50.
Also have a aluminum bellhousing 2892482, 10.5" fits all small block a, b, c or e-body 69-71 = $150
Small block 727 inspection shield - Sold
exhaust manifolds 67-69 a-body 273/318 -Sold
new black jack aluminized headers small block a-body - Sold
seven blade fans - Sold
power steering pumps with bracket and pulley, Federal and Saginaw - Sold
67 273 finned small block valve covers - Sold
Sold 2 rallye wheels, have 2 left.
pic attached
