Mopar performance 528 solid cam for a small block.
DusterKrazy
East Tennessee
Looking for the Mopar Performance 528 solid cam for a small block (LA engine). I am on a tight budget and am looking for a good deal on one.
It can be used but not abused. If you have one, hit me up.
I have a custom grind Comp Cam solid cam. I don't know the mopar perf 528 specs. This cam has .547 int. 532 exh. 250-254 w/104 lobe sep. Cam, lifters springs,titanium retainers and comp keepers. Dyno time only. My customer changed his application. This cam has a rear cam drive set-up that was for sprint car. Cam drive is threaded in and is very easy to remove. I will remove for you if needed. This set-up new was over $500.00.
Looking for $200.00 for complete set-up. If interested I will give cam grind #. Comp cams has all cam info. on file.
