[SOLD] Mopar rebuilt distributors
halifaxhops
It's going to get stupid around here!
Hoppyworld, PA
All distributors were completly taken apart, cleaned and new points/cond. steel shaft bushing and run on a Sun distributor machine along with the results.
SLANT 6
66 2444255, 65 2444648, , 66 2444648, 2875822 (1bbl )
LA
67 273 2642238, 72 318 3656275, 56-61 354 hemi 1634193, 624318 2444259, 68 340 (4bbl) 2875105/IBS-4015A, 67 273 (4BBL) 2642242 (IBS 4013A) 72 340 4bbl 3656278, 65 318 2bbl 2444259, 72 3656278 340 4 bbl mt/at, 67 2642242 (IBS-4013a) 273 4bbl mt/at, 71 3438225 318 2 bbl, 70 3438225 318 2bbl, 70 3438317 IBS 4015C 340 4BBL, M/T, 360 CUSTUM ADVANCE, 63 273 2444791, 73 360 365780, 74 340 (240 hp) 3656771, 69 318 2875796, LA prestolight with a petronix unit Mech advance, 73 3755365 360 2v, 72 318 3656587,
B
65 361 2642244, 71 400 3656329, 65 383 IBS 4006J, 74 400 3755681, 71 383 3438690, 65 361 2444676, 57 354 IBB4105B, 76 400 3755157, 68 383 2875354, 76 400 3755757, 68 383 2875354, 69 383 2875750 330 HP M/T, 70 383 4v elect vac adv 3438233, 66 383 2642244, 74 3656593 400 2v, summet hp, 71 3438534 383 275hp, 72 3656593 400 2v, 71 3438534 383 275 HP
RB
68 426 2642252, 64 413 2444263, 68 426 SUPERSTOCK tach drive 2875327 IBB 4401a, 83 4120942 426/440 MP TACH DRIVE, 68 2875362 440 4BBL A/T 350 HP, nice aftermarket elect nice curve, 70 3438219 440 350hp, 65 426 hemi 2444721, 70 3438219 440 4v elect adv, 65 2444676 383, 72 3656596 400 elet adv, 72 3656365 440 (6 pack?) 66 2642252 426
MOPAR PERFORMANCE
(2) MP 3690432 RB,
Mallory
YL-579HP ( LA), YL-577HP (B)
Accel
20302 (B)
CORES TO BE REBUILT
SLANT
62 2098670 1BBL
LA CORES
73 340 3656771, 83 4145753, 78 4091161, 74 3874090, 56 IBJ 4301A 270, 56 IBJ 4302A, DESOTO 330, 67 318 2642718, 72 318 3656587, 72 340 4BBL 3656278, 65 318 2098685, 75 318 3874090, 78 318/360 , 73 318 truck, 78 360 4091661, two 73 360 3566677, 71 318 3438225, 68 340 2875346, 78 360(hd) 4091661, 71 318 3656365, 71 318 3438255, 73 360 3656780 40/2, 69 318 2875796, 68 318 3755201, two 74 360 (4v) 4091661, two 318 3656763, 74 318 3656763, 78 318/360 4v 4111487, 79 318/360 HP 40911140, 73 4145604, 78 4091661, 80 4289980, 72 3656363, 340 4bbl MT, 73 3656763 318 2bbl AT/MT, (2) 72 3656278 340 4bbl AT/MT, 63 2098685, 75 3874090 318 2BBL, 78 4091140 318/360
67 273 2642238, 72 318 3656275, 56-61 354 hemi 1634193, 624318 2444259, 68 340 (4bbl) 2875105/IBS-4015A, electronic la 72 up, 67 273 (4BBL) 2642242 (IBS 4013A) 72 340 4bbl 3656278, 65 318 2bbl 2444259, 72 3656278 340 4 bbl mt/at, 67 2642242 (IBS-4013a) 273 4bbl mt/at, 71 3438225 318 2 bbl, 70 3438225 318 2bbl, 70 3438317 IBS 4015C 340 4BBL, M/T, MOPAR REBUILD LA R0212104, 360 CUSTUM ADVANCE, 63 273 2444791
B
65 361 2642244, 71 400 3656329, 74 400 3755681, 66 383 2642363, 71 383 3438690, 65 361 2444676, 57 354 IBB4105B, 76 400 3755157, 68 383 2875354, 76 400 3755757, 68 383 2875354, 69 383 2875750 330 HP M/T, 70 3438231 383, 67 2642718 383, 4091709 400 hp, 68 383 2875358 383, 2 209572 IBP 4005e, 67 242727 383 270 hp, 65 383 2444676, 69 2875747 383 2v
RB
68 426 2642252 426, 71 3438559 440 4bbl AT electronic vac advance., 75 4120942 IDH 4007 42 tach drive, 74 3755518 440, 72 35341 440, 9 2875764 440, 73 3755157 440, 72 3656341 440, 68 2875102 ibs 4014 440, 68 2875362 440 350hp 63 413 HP IBS 4011
MOPAR PERFORMANCE
MP 3690432 RB,
Mallory
Accel
20302 (B)
Early
Done
1939-40 six Igs 4108
Early cores will build upon request
IBS 4013 39 PACKARD, IGS 4111-1 41 DODGE D-20, IAT 4101 53 DODGE D46-47, IAP 4103A 49-50 PLYMOUTH P-18, 19, 20, IAP 4101-1 49 DODGE 237 CI,
IGS 4203C-1 42 PLYMOUTH P-14, IGS 4207-1 50 DODGE WAYFARER, IAT 4003 51-52 CHRYSLER 230 CI, IGS 4203B-1 42-48 DODGE D22 D24., 73 3656771 340 4BBL MT/AT,
All I have for 68 340 is a ibs 4015a, 2875105 the auto one. The curve is a bit more.
300 is as low as I can go the cores are $$$ Shoot me a message. You want numbers or any one that the curve is right on will work?
PM replied. Please when asking for application add, year, motor, carb and what trans.
Thanks!
I tried to PM you direct, but either this site or my puter. What will a reurved rebuilt points dist for slant six run, and the specs. 77371 Tx. None of my cars have original engines but all are peanut heads. I read where recommended specs are 15 int., 30 total all in by 2800. Is that right? Thanks BILL
I will shoot you a pm. Usually for a slant 150 any curve you want and a new gear if you have a core.
