[SOLD] Mopar Small Block Steel Bellhousing Scattershield & Block Plate
ESDuster
Member
Houston, TX
Mopar Small Block Steel Bellhousing Scattershield & Block Plate - EBAY auction, NO RESERVE! ITEM: 251430246829
Up for bid is a used small block Mopar steel bellhousing - scattershield with block plate included. Scattershield will fit 273/318/340/360 blocks with 4 speed manual transmission. IMPORTANT: bellhousing accepts transmission input bearing retainer diameter of 5.125 inches. Smaller retainer diameters can be accomodated by using custom register ring - spacer (NOT INCLUDED).
Bellhousing has been modified as follows and as shown in photos:
  • Upper portion of bellhousing trimmed for ease of installation (6 outer fastener holes removed).
  • Clutch fork pivot land height reduced ~1/8 inch. Can be adjusted by shimming if desired.
  • Ground 2 "arcs" for increased clutch fork clearance.
Be sure this part will fit your application prior to placing bid. Do NOT hesitate to ask questions!
It sold
[ame="http://www.ebay.com/itm/251430246829?ru=http%3A%2F%2Fwww.ebay.com%2Fsch%2Fi.html%3F_sacat%3D0%26_from%3DR40%26_nkw%3D251430246829%26_rdc%3D1"]Mopar Small Block Steel Bellhousing Scattershield Amp Block Plate 340 360 318 273 | eBay[/ame]
