[WANTED] Mopar Stage VI #5249579 intake rockers
Good luck with that. I have a set of Stage VI heads I'll be using on a 512 build this spring. Mine are std port and use the std rocker arm. Are yours the Chapman modified version? I hear they really flow well!
Harland Sharp may be a good source, that’s what I use.
Yes I can Special order them, but I was hoping to find a set someone bought and didn't use. The intakes are the only thing different the exhaust rockers, shafts and hold downs are the same as stock.
Hey Roy, are these the rockers that are 1 1/2 times the width of the regular rockers. I know they don’t work on a regular stage 6 head. They are crane golds. These are my buddies. R L. Regular. Kim
Do all of the Stage VI rockers require the offset one for the intake side? Or just the Chapmans, and Max Wedge size ports. I'll be using the original type Stage VI heads, along with 440 source rockers. Hope they line up OK.
Do all of the Stage VI rockers require the offset one for the intake side? Or just the Chapmans, and Max Wedge size ports. I'll be using the original type Stage VI heads, along with 440 source rockers. Hope they line up OK.View attachment 1715293308
Just the MW port Stage VI. They relocated the intake pushrod location. That is the reason the intakes need to be .450 offset.
