[SOLD] Mopar throttle and passing gear rods
chargerjoe68
pennsylvania
i have various brackets and passing gear rods and cables
4 small block throttle brackets $25 each
3 long rods for passing gear $25 all
3 short passing rods $40 all
2 a body z bars for auto $25 each
4 throttle rods sold
7 alternator and power steering brackets
$35
10 other misc brackets ball mounts and throttle spring holders $25
$100 for everything
Accepting any reasonable offers
Located in western pa
If that is 35$ for all the throttle rods I will take them and the spring bracket below the gold altanator brackets it is the dirty one with a shiny end.
How do I tell?
Thats the problem I am having. Dont know what the inner lever closest to the trans angle is supposed to look like. Cant find pics. Im swapping from 225/904 to V8/727 in my 69 Dart and was told the z bars (cross shafts) do not interchange. Anybody have pics of the correct column shift V8/727 A body Z bar (trans cross shaft)????
U got anything correct for a 360 4 barrel. Kim
The top 4 throttle linkage are all off small blocks the gold one below is 360 and the 2 alternator brackets below are Small block
The z bars are a body for column shift
Let me know what you need and I will make you a good deal
