Mopar Vintage Dana 60 Original 1968 Build date 05-27-1968 Power lock Track Pack Unit, 513 Gear Ratio, plastic Dana Green plug, backing plates with 11 inch finned Brake Drums, measures B Body 54 ½ inches flange to flange, spring perches moved inboard for larger tire clearance.
This Dana was under a 1969 Dart same as in the 1968 Hemi Darts which all ran the Mopar B Body Dana 60.
Cleaned up the axle tubes but I left the markings on the third member.
South Bend IN. 46619
$1650.00
$1650.00
