more imfo on 360 block/crank
alsdemon
portage lakes ohio
the date is 24/6/77 other side 5901 360/ on driver side front of block 03525c then last was crank 3418640 any help thanks. alan
crank =cast iron 71-86 with 74-75 being shot peened.
june 24th 1977 block, run of the mill with the large thrust bearing, make sur you order bearings or at least the thrust, for a 74 & up.
thanks i needed some where to start. aian
Update removed the crank bearing look nice no copper , thy like the rods are 10 under. Removed freeze plugs. Block was full of rad. stop leak. and two of the cam bearings are off center of the oil hole.The motor was a reman from a trailduster. Must had a leaky rad. going to send to shop to have tanked and new cam bearings then I will take it from there. alan
