Mopar-Man
Big Block Better Burnout
Hey guys!
I have a solid front motorplate (not elephant ears) and I have no idea how to mount an alternator. I want to go with the 440 Source serpentine kit. I am using manual steering and no a/c so I ony need single groove pulleys. I plan on machining the water pump housing and removing the same amount as the thickness of the plate. Now, the problem is how to make an adjustable bracket for the alternator that bolts to the motor plate. Can you guys upload some pictures of how you have done this? I would like to run a one wire alternator and I have NOT purchased one yet.
THANKS!!
THANKS!!
