Move car around
Hallzy
Alberta,Canada
Just wondering what others have done to move their cars around. Car currently has no rear end and I am redoing all the suspension and dropping the Kmember out to get everything ready to install engine and trans from the bottom. So that being said what have you guys done I'm just spitballing for ideas I have a engine stand, hoist, and welder and all so fabricating something up is fine I would like to be able to have the *** end on casters and use the hoist at the front that way I can roll everything around in a fairly small garage. Thanks in advance for any input and ideas
Ignore the extra brackets sticking out of the rear one, the wheel and cross section just gets used over and over again and the required uprights get welded onto it for the current job.
I did the same thing dadsbee did and made a set for the front that bolted to the front bumper mounts. Made moving the car around the garage very easy
Thanks I'm more interested in the back though the front will be easy with the hoist and jack stands i want to keep the front as open as possible for installing the engine and trans and front suspension all at once looking for ideas on some sturdy movable footings for the back that can handle when the front end is lifted high to slide everything underneath for install
