MRL Performance
This is an engine that Im building right now, well in the process of building. Its one of our New lines of engines to go along with our Classic Cruiser line.
Let me introduce to you the FreighTrain!!! Because it will pull like a Freaking Freight Train! The FreighTrain line will run on race gas for the most efficient power, remember compression makes better power
This one is going to be a 500ci monster from a 400 block. When done it will be up for sale. Im looking for someone who wants to put a deposit it down on it so I can finish it off and get it on the street/track. This is going to be a Special deal and you wont find a better, more powerful engine for the price.
First let me give you the run down
400 block prepped and ready to build
500 stoker kit i can not seem to sell w/JE pistons, I beam rods ect
Main girdle w/studs
M/W ported Eddy Victor heads(from a member one here)
Hughes roller rockers
Custom MRL solid roller cam
MRL Pro Plus roller lifters
7qt+ oil pan 1/2" p/u
Fab aluminum valve covers
Eddy Victor intake, ported
Dominator carb w/2" adapter
Billet timing set
Mallory dist
Mallory ignition box
Plugs and wires
Anti friction coatings throughout
MRL top end oiling mod
Power should be in the 750-775HP and 675-700TQ range. All done by around 6500-6700rpm!
You have seen my builds, so you know Im not all about the Peak numbers, but the most average power I can get for a setup. It should carry 650+TQ from 4000-6000rpm!
As mentioned, Race Gas 13 to 1 compression.
This engine will be complete, carb to oil pan, dynoed and ready to ROCK N ROLL.
Normal price for this engine would be $16,750
This Special One Time Only Price $14,500!
Main girdle w/studs
Billet timing set
Mallory dist
Plugs and wires
