[SOLD] MSD 7 AL with several pills, sent to factory and back
SGBARRACUDA
ROY
Legendary Member
PLANT CITY FL.
For sale is a used MSD 7AL. It has been sent to the factory to be tested and has not been used since. Comes with the paper work from MSD. Included are several RPM pills between 4000 and 7600. Also includes the rubber mounts. $150.00 shipping included in the USA.
Basically the same but if you want to ad a pill for a trans brake or a pill for your burn out, you have to use a two step or three step if you want all three rpm limiters.
Yes, if you look up the Blaster 2 coil it states it will work with MSD 5,6 and 7 series boxes. No you can run them on the street or strip. Hot Rod magazine did an article on this years ago.
