1969dodgedartgt
hey guys,
I just successfully rebuilt my carter bbd 1 1/4" solid fuel carburetor. All went well but I was a bit confused with some of the adjustment settings and it seems this is causing a problem.
If I go from no to full throttle quickly the car is prone to die. I also had a loud bang (backfire through carb?)from the engine when doing this once.
I did not check float setting, was kinda hoping that it seemed to be ok before and still should be. The pump adjustment setting could easly be the problem because it says to adjust the untill the pump shaft is a specified distance below the dust gasket cover, but I could not find what distance this is suppose to be. Also my vacuum piston spring was missing and still is.
please let me know what I should check for this dieing on zero to full throttle problem.
Thanks and some pics.
