skep419
5.9 Magnum 4 speed afficionado
Need some help on what I can ditch under the hood. Looks like a ton of emissions garbage.
You'd need the 32/26 DFEV, not the DGEV. The DGEV is reverse rotation on the throttle arm. You could make it work, but the DFEV is easier.
And there are other OEM carbs that are the same bolt pattern, pintos, caravans, etc., but they are getting hard to find, will definitely need a rebuild, and most of time were emission carbs too. It's gonna be way simpler to just buy a new carb.
If it runs, leave it alone and drive it.
The 2.2l will knock, they all did. Wrist pins. But it won't be a problem, just an annoyance.
Go thru the battery cables, you'll likely need to replace both. They're probably green with rot.
Keep a map sensor handy, and check the potting in the ECU/PCM. Seen a lot of them get cracks in the potting and allow water to short the electronics. You'll know if the potting is bad if you're driving on a rainy day and the car just shuts down on you.
I'd love to have another one of those things. I miss those 2.2L engines.
I know where there's a 89 turbo II engine sitting in a garage with 75 k on it....
If it's free and somewhat close to SW Minnesota I'm in.
Yep, that would get it on down the ole' road....Easy fix. 340 and a 4 speed.
