[FOR SALE] N.O.S. direct connection crank trigger bracket SB
ssba
rensselaer in
Here's one you don't see every day.
This is part# P4007208. Probably discontinued since the 70s or 80s.
New never bolted to a engine. It has been stored well and looks like it
was made yesterday. Still has the old tag to give its age away.
Made for the small block Mopar. Made to hold two triggers. One
for start and one for run. Start trigger position used on engines over
12:1 compression. Thought I'd see if someone here could use this
before listing on eBay. May be able to be used with efi? Bracket is
anodized aluminum. Top quality old Prostock part.
50.00 shipped to the lower 48 states.
That picture you posted is the very same part. Not one just like it the very same one.
I bought the set up for a Hemi and didn't need the small block bracket that the original
purchaser had planned to use the kit on. The brackets came separate from the kits.
The constant output voltage regulator was also a separate part #.
I have been buying impossible to find parts for 15 years now for this car to keep it
accurate to the era down to the last bolt.
The day I won that auction I did a little victory dance. One of many key parts to the puzzle.
