Name this carb
Redbull
Member
1971 dart slant 6
Door Stop ? Just kidding. I cant remember but I do believe Holley..
I will guess that the carb is a 1971-77 ?
They ran very lean, dealership customers would complain about poor driveability .
There was a trick if you removed the tin cover there was a adjustable screw,maybe a allen screw that you would bottom out that would help with better driveability.
1977 was my last year at the dealership so I'm a bit foggy about it.
Def a door stop but i cant find one online like
If you don't need all the emission junk find a Holley 1920. Should bolt right up.
Can confirm Holley 1945. I’m running this exact same carb on my ‘75 Dart /6. Eventually planning to upgrade intake to a 2 bbl setup. Car does tend to lean out/temporarily stall (especially, when exiting highways).
