wedgmastr
Member
Up for sale is a s&w ladder bar frame kit- the frame is 24 inches wide, it is fully welded, it comes with 32 inch ladder bars with the upgraded adjustable moly rod ends,pan hard bar, qa-1 adjustable aluminum coil over shocks 4-5/8" single external adjustment, coil over spring 130 lb 2-1/2 x 12 , i also have a narrowed mopar 8 3/4 rear made for this frame, it has the back brace on it , brand new yukon nodular iron center section, strange spool with 410 gears, heavy duty moly differential yoke, strange axles with screw in moroso wheel studs 3 inches long. I had bought this set up for a car that i was going to convert to an old time gasser with new technology - but due to financial reasons i had to abandon the project. All parts have not been used- i painted the frame and the rear housing so it would not rust. I am sorry to see it go. I was looking to get $4,250 for the whole set up - but i am open to offers. The whole setup is in northport ny
I AM HAVING TROUBLE UPLOADING PICS- TO SEE PICS GO TO EBAY AND TYPE IN ITEM NUMBER 300657081789 YOU CAN SEE THE PICS THERE.
