Well...kinda found my own answer right after posting this, hehe..."LCA is the same for all A-Bodies, except for sway bar tab. UCA will be changed if using 73-up big bolt pattern spindles, due to larger upper ball joint. Lower ball joint is the same all years for disk and 10" drums. You will need to change lower ball joints only is you are swapping disks onto a car which originally had 9" drums"
I do have 9" drums all around, so, I guess that I will need to get 73-up LCA's.
