Need information about center sections
NEWATTHIS
Hi everyone,again i need your help, this time its about centre sections. In my 74 dart sport iam running the 7 and a quarter rearend with 276 gears. the plan is it move up a 489 8.75 sure grip rear end with 410 gears. My question is this, does all mopar 8.75 center sections come with a 30 spline? Did any come with a 29 spline? or was that on the 8.25. I Also was wondering if i can use my axles with the 8.75 center section. Will there be any other changes like the yoke or u joints that i will need to change also. Any help and information is grateful. thanks .Newatthis
Yes
No. The pinion spline where the yoke installs may have a 29 or 10 spline
Can't use the 8.25 or 7.25 axles in the 8.75
Depends on the yoke 7260 small 7290 medium, 1350 large. Even if the sahft and yoke are different, you can get an adapter U-joint that has a 7260 on one side and 7290 on the other. Driveshaft will definitely need to be shortened.
