Need to Mount PS Pump on '68 340
charliec
richmond texas
My '68 Dart w/340 came with a power steering box, but the pump/brackets/belts, etc. were all missing. I bought a TRW pump and brackets, and I had the pump rebuilt at Steer & Gear. Now I'm ready to install it, but I don't know exactly where the brackets should mount. I can make some guesses, but if someone has a similar setup, it would be most helpful to have a few good photos.
Attached are photos of what I have now. I'm guessing that the bosses where I have my fingers are for the mounting bolt and the belt adjuster/tensioner. Correct?
Does the pump drive off of the middle sheave of the crank pulley?
Ps belt goes to outer sheave on crank pulley. Be careful with top bolt, I only loosen it enuf to adjust/tighten belt. It may lead to coolant, I cant remember
View attachment 1716477314 View attachment 1716477315
Thanks. That helps. Your "outer"sheave is my "middle" sheave because my crank pulley has three sheaves.
