[SOLD] New 2 bolt master cylinder 1&1/32" bore
moparmat2000
Grand Tetons
New unused aftermarket 1&1/32" bore late model 2 bolt master cylinder. Has o ring groove in the back. Best if used with larger bore 2.75" piston calipers. Plastic reservoir is a cleaned used oem mopar part. Located in west Texas. Asking $35 plus shipping. I accept paypal.
84-89 M body or 78-79 B body calipers are direct bolt on to 73-76 A body slider type caliper brackets, and use same pads. M body calipers are SAE thread as well and utilize same banjo bolt, which is located in same location as A body caliper.
bump
will do this master cylinder and my 4 to 2 master cylinder adaptor as a combined sale for $60 plus shipping.
bump
I might be interested in this set up, my 67 cuda has disc up front. I think from a 74 duster ? Do u have a prop. Valve ? To go with it ?
Many thanks, just need to be sure will work for me.
Let u know , asap
Nope not saying that. Tou have to determine if a 1&1/32" bore is going to work with 4 piston calipers. Whats the piston dia x 2 to find surface area. These work great with a single 2.75" diameter piston caliper. Get out your slide rule do some math.
They work fine.
