[FOR SALE] New SCAT and Diamond Forged Mopar 360 & 5.9 Magnum Stroker Rotating Assembly - 408”
Rocket
CT
I have a new SCAT forged rotating assembly for 360 & 5.9 Magnum Mopar engines. All parts are new high-quality parts. Final cubic inches will be 408”.
The assembly includes the following parts.
  • SCAT forged 4.000” crankshaft part # 4-360-4000-6123
  • SCAT forged H-beam connecting rods with APR 2000 bolts part # 2-360-6123-2124A
  • Diamond Forged flattop 4.030” bore pistons (0.030” oversize) part # 51026
  • Trend wrist pins - 0.984” part # TPD-G9842750155
  • Diamond wrist pin locks
  • Mahle file fit ring set with Moly ductile iron top rings part # MAH4035MS
  • Speed Pro Tri metal Competition Series rod bearings part # 8-7125CH
  • Clevite P-Series full groove main bearings part # MS-1266P
I have the equivalent stroker assembly for a 340 with new Diamond 4.060” (0.020” overbore) flat top pistons, Perfect Circle file fit ring set with Moly ductile iron top rings part # 315-0036.065, Speed Pro Tri metal Competition Series rod bearings part # 8-7125CH and a SCAT forged 4.000” stroke 340 main crankshaft. All parts are new. Displacement would be 414 ci.
If you are looking for a 360 stroker with lower compression, I can substitute the pistons and connecting rods for new SRP 4.030” dished pistons part # 220156 (16.9 cc piston head volume) and new Eagle H-beam rods part # CRS6123C3D (360 stroker assembly only).
This rotating assembly will need balancing.
The price for the complete kit with the Diamond flat top pistons and SCAT rods is $2,750 plus shipping cost.
The price for the complete kit with the SRP dished pistons and the Eagle H-beam rods is $2,600 plus shipping cost.
I can also meet in CT to save the shipping.
PM me with any questions.
I do not have stock style pistons unfortunately.
